• 02.10.2026, 13:35
Ytterbium
Auto invert not inverting on HighFlow Next
vendredi 27 mai 2022, 15:24
Hello,
I mounted my high flow upside down so I selected the rotate option, I left the default to rotate the screen and colors but it never seems to change from inverted to default.
Any suggestions no how to restore the expected functionality?
vendredi 27 mai 2022, 18:13
Rotate & Invert are two separate functions
  • Rotate physically rotates the display 180° to match your Flow NEXT's upside down orientation
  • Invert toggles the pixels in the display between black and white (immediately)
  • Auto invert switch the pixels at a predetermined period (do not know the timing)
Ytterbium
vendredi 27 mai 2022, 18:47
OK, could be that the auto invert just did not do it in the time frame I expected. I thought it did one cycle of display in light then one cycle in dark but it could be something else as you say.
Thanks for the comments
