• 13.11.2026, 15:00
bobbler
Newbie Question/Build
lundi 24 janvier 2005, 14:39
Just want to check that I have everything here for a basic setup and that it will be able to sufficiently cool if I add a couple of Aquabays and a graphics card cooler at a later date:
12V Aquastream Pump
160mm Radiator
160mm Radiator Cover
Cuplex Pro CPU Block
Aquatube Reservoir
Tubing
Anything I need to add to that little lot to get started?
Thanks in advance
Re: Newbie Question/Build
lundi 24 janvier 2005, 15:09
Hi and welcome to the forum :)
Looks good but don't forget to buy all necessary connectors. When ordering the radiator you will have a selection box to choose the connectors. For the pump you will need 'Anschluss-Satz für aquastream und Eheim 1046'.
You will need ac fluid. It's a a concentrated anti-corrosive water which will be mixed into the distilled water.
Maybe you should order one or another elbow-connector ('winkel').
bobbler
lundi 24 janvier 2005, 16:15
Cheers Shoggy, though now I am even less sure about what I need to get it all working :)
So the Aquastream is not a pump just the controller so I need the Eheim 1046 and the connector pack (nr 41011) to actually pump water through the system?
This is what I currently have in my shopping basket to buy:
34903 aquajet - Spuelleitung fuer aquatube 1.1
34905 Einbaublende Aluminium silber eloxiert fuer aquatube
34101 aquatube Rev. 1.1 Blau (plugncool gerade)
21211 cuplex PRO Vierloch-Halterung AMD (plugncool gerade)
31053 airplex evo 160 (plugncool gewinkelt)
32012 Einbaublende aus Edelstahl fuer airplex evo 160
41043 aquastream Pumpe 12 V Rev. 3.0
53101 ACfluid - Korrosionsschutz 50 ml
51030 Waermeleitpaste Arctic Silver 5 Inhalt 3
61011 (m) Schlauch PUR active blue plugncool
63018 Kugelhahn mit plugncool-Anschluessen
63017 Schlauchschneider
51051 AC Multi-Tool
53103 ClearBlue Wasserzusatz 50 ml
34912 Beleuchtungsmodul UV fuer aquatube
41011 Anschluss-Satz fuer aquastream oder Eheim 1046
lundi 24 janvier 2005, 22:27
Aquastream 3.0 is the controller and aquastream (modified Eheim 1046). It's impossible to connect any other pump to the controller.
Your list seems to be ok.
I recommend to buy a normal led instead of the uv led for the aquatube. You could get the blue led, the effect will be much better.
As mentioned before it could be useful to have one or an other elbow-connector.
