• 18.11.2026, 00:59
RE: RE: High Flow Next - Can I use it with just USB 2.0 header or aquabus is mandatory?
mercredi 20 juillet 2022, 16:47
Sebastian
I saw an answer once,
aquabus is an old channel reserved for linux-like operating systems, is it correct?
Most peripherals can be connected to a PC via USB 2.0 for firmware upgrades and communications.
HUBBY7 is a part with USB2.0 expansion function, which can connect seven USB2.0 peripherals.
in addition,
Some peripheral sensors must use aquabus to communicate. For example,
electronic temperature sensors such as Calitemp still rely on aquabus ports to connect to aquaero 5/6 XT or LT.
I installed four calitemp sensors, which are used in the water inlet of CPU and GPU. and water outlet.
Temperature data is very accurate. Other than that : USB2.0 is a must, but aquabus is not. :)
Mostly correct.
The aquabus is only available if an aquaero is in the loop, and it is useful if USB is not available (e.g. extrenal radiator with aquaero, no USB to computer)
Discussions similaires
