• 20.11.2026, 22:54
pangeng
may i ask if aquabus cover the function of usb port?
samedi 13 août 2022, 18:20
for example the product
Aquacomputer OCTO fan controller for PWM-fan
it has both aquabus and usb port. If I connect this fan hub to aquaero 6 via aquabus and connect aquaero to motherboard via usb, do I still need to connect this fan hub to mother board via its own usb?
P.S. does this fan hub have its own firmware that to be updated by aquesuite?
Best
Geng
dimanche 14 août 2022, 07:34
The Aquabus is used to expand the Aquaero, if you connect the OCTO via Aquabus, the Aquaero gets 8 fan ports and the temperature sensors additionally in the Aquasuit, these connections are then only controlled via the Aquaero tab.
The remaining functionality, such as RGBpx continues to run via the OCTO and can only be controlled when the OCTO is connected to the motherboard via USB, the same applies to the firmware updates.
The Aquabus only makes sense if you use another operating system than Windows and want to control as much as possible directly via the Aquaero, since the Aquasuite only runs under Windows.
Translated with www.DeepL.com/Translator (free version)
Discussions similaires
