• 16.11.2026, 13:40
tiggerlator
OCTO Alarm Shut Down
samedi 17 septembre 2022, 21:07
just connected the signal connector on my AQ OCTO to the power button. set alarm to activate the connector switching the PC off if the pump drops to 0%
I tested it with the continuity setting of my multi meter, and it works.
I7 12700k - Asus Rog Strix z690-A WiFi D4 - TEAM GROUP 2X16GB DDR4 3600C16 - MSI RTX 3080 GAMING X TRIO 10GB - Crucial P5 Pro 500GB M.2 NVMe Gen4x4 - WD SN850 1TB M.2 NVME Gen4x4 x2- SanDisk 2TB SSD PLUS 2.5" - Corsair RM850X - Lian Li o11D XL - EK 360mm PE - EK 360mm XE - EK supremacy classic - Generic (GPU) - Ultitube 150 D5 - dell s2721dgfa 27" nano IPS 165hz Custom corsair PSU cables
dimanche 18 septembre 2022, 22:00
Yes it works, and is a clever idea that provides a major safety feature for the cost of a bit of wire, 2 connectors, and 1 digital output bit. I think it holds the contact pair low for 1-second. Be careful about how you set up the Alarm trigger. When I got mine, while testing, I inadvertently set the Alarm trigger to a condition that normally occurred when AQS service and GUI start up. The result was every time AQS started, the alarm would trigger and the computer would shut down. Oops. ;(
Ce message a été modifié 1 fois. Dernière modification effectuée par "Speedy-VI" (18 septembre 2022, 22:03)
tiggerlator
lundi 19 septembre 2022, 10:35
Mine seems ok. Set it so if the pump goes 0 it will switch. It boots up fine, so should be ok. I like the fact i can leave it on and go out and if the pump fails, it will save itself. It's pretty easy to set up, not sure why others have a problem. I even made the cable myself till the AQ one comes in the post.
Ce message a été modifié 1 fois. Dernière modification effectuée par "tiggerlator" (19 septembre 2022, 10:36)
Remayz
lundi 19 septembre 2022, 12:47
it's because you made a simple alarm :p When integrating it as part of a more complex virtual sensor, things may go south hehe
tiggerlator
mardi 20 septembre 2022, 13:06
for me the pump is the important thing, if it dies my PC does so the alarm control is on that only.
Pretty pleased with the OCTO tbh
