• 19.11.2026, 15:18
Caldorian
Can’t get Leakshield to consistently seal
vendredi 23 septembre 2022, 17:22
I’m having difficulty getting my leakshield to consistently seal with the reservoir so that the pressure doesn’t “raise” (?).
I originally had the leakshield on my system, and it would need to pump a few times a day to keep the vacuum. A couple weeks ago, I re-did my loop, and at the end, made sure to pressure test everything but the res/pump/shield, and no leaks were shown. Finished the plumb and it was all good. Barely any pumping for the 2 weeks. However, I only had the red about half filled.
So yesterday I popped the leakshield off, topped the res off, leaving about 20% left, and put the shield back on. And now it’s back to leaking pressure again, having a consistent leak between 0.5-1.3 mbar/min. I tried putting the leakshield back on 3 times, and every time it’s been the same.
Any help would be appreciated.
Ytterbium
dimanche 25 septembre 2022, 11:02
I found putting a little dp ultra on the seal helped.
I also found that lower pressure is pulling a tube off a little so now I run in monitor mode until I can rebuild loop
