• 13.11.2026, 09:08
richman
System PC 70 Variante 2 Questions
jeudi 27 janvier 2005, 12:28
Hello all.
I have been looking into going watercooling for a while now and have finally pluckec up the courage to take the plunge (well hopefully not literally) i have some questions regarding one of the pre-made packages that you sell. If someone could please help me with this i would be more than greatful.
- What EXACTLY Do you get with the System PC 70 Variante 2
- What pump is included with the set-up
- What Radiator is in the set-up
Cheers
Richard
pharao
Re: System PC 70 Variante 2 Questions
jeudi 27 janvier 2005, 12:59
What you'll get:
Lian-Li PC70,
aquabay at
aquatube silver
aquastream <= Pump ;)
Entkopplung für die Eheim-Pumpe
airplex evo 160 <= Radiator
2x YS-Tech 80mm Silent-Lüfter
2 Verlängerungskabel für Lüfter
2m hose plug&cool natur (extra),
thermal heat sink paste,
AC-Fluid
What you'll need
a PSU
the CPU-Cooler you actually want has to be bougth seperate.
richman
jeudi 27 janvier 2005, 13:57
iam new to this area of computing so lets clear some things up that iam, not sure of.
Lian-Li PC70 - This is obviously the case
aquabay at - Is this a mount to put the AT into the drive bays?
aquatube silver - This is a silver aqua tube
aquastream - This is a pump with control panel (yes?)
Entkopplung für die Eheim-Pumpe - I dont really know what this is even after trying ot translate it
airplex evo 160 - This is the rad ;)
2x YS-Tech 80mm Silent-Lüfter - These are the fans i think
2 Verlängerungskabel für Lüfter - These are extension leads for something could u let me know what?
2m hose plug&cool natur (extra) - This is the hose that is used to create the loop ;)
thermal heat sink paste - Speaks for itself
AC-Fluid - This is the fluid.
Once i place my order how long approx will it take for AC to ship this to me (uk)
Also will the case come with everything installed so i dont have to do any modding of the case?
Cheers
Rich
pharao
jeudi 27 janvier 2005, 14:10
2 Verlängerungskabel für Lüfter - These are extension leads for something could u let me know what? extension cables for the fans
right
right
right
they're used to isolate the case from pump' vibrations
The system comes pre-mounted (can you say so?)
richman
jeudi 27 janvier 2005, 14:14
Thanks this is prolly the best option for me then?
If the system does come pre-mounted that is great :)
Do you know where the radiator is located on this system??
Rich
pharao
jeudi 27 janvier 2005, 14:22
On top of the PSU:
jeudi 27 janvier 2005, 14:23
The radiator is mounted above the PSU:
edit: hobbes_dmS, one day I will be faster... ;D
richman
jeudi 27 janvier 2005, 14:29
Cheers guys.
How much is the shipping on the UK on one of these.
Rich
pharao
jeudi 27 janvier 2005, 14:30
dunno. u can ask sb at support@aqua-computer.de
shoggy: never ever...  ;D
