• 22.11.2026, 02:38
Maki911
D5 NEXT AND AQUAERO 6LT-Cant read fan speed anymore and how to import CPU/GPU temp data in Aquaero?
mardi 3 janvier 2023, 15:58
Hello ,I need some help from WC community, so my Aquaero 6LT stopped reading fan speed,im using nzxt aer rgb 120mm over fan connector on aquaero,but I can only change power slider cuz there is no other info.And also,how to import temp data of CPU i GPU in aquaero? Also if I can add one farbwerk question,why cant farbwerk 360 daisy chain 6 120mm NZXT Aer RGB fans? :S Any help would be greatly appreciated .
Remayz
mardi 3 janvier 2023, 18:52
If you plug the NZXT controller to the farbwerk to control it, you're limited by the NZXT controller (40 leds max : 5 fans max).
https://support.nzxt.com/hc/en-us/articles/4578100565659-Connecting-AER-RGB-2-Fans#:~:text=Each%20NZXT%20RGB%20fan%20has,five%20RGB%20fans%20per%20channel.
You'd have to get rid of the NZXT controller and connect the fans directly to the Farbwerk through a Splitty 4 (to adapt the connexion)
https://shop.aquacomputer.de/product_info.php?products_id=3766
This way you'll be able to use the Farbwerk limit of 90 leds.
Maki911
mercredi 4 janvier 2023, 00:30
I did ditch nzxt controller, I do have 2 RGBpx Splitty4,but I cant daisy chain on one RGBpx Splitty4 6 of them,but on the other one I can,so I will buy the third one for the remaining 2 fans.
Discussions similaires
