• 17.11.2026, 17:56
omgrubberduck
Unable to install Aquasuite X.67
jeudi 9 mars 2023, 22:56
Getting an error stating that I don't have .NET 7 Runtime even though I definitely do. See image below.
Tried having just the x86 one installed, nope, just the x64 one, no change either. I'm downloading from the link given in the installer.
Methodical
jeudi 9 mars 2023, 23:33
Is it this one that was posted in the Change Log?
New: aquasuite X
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
omgrubberduck
vendredi 10 mars 2023, 19:55
Yes I tried that one too, which is the same one linked in the installer. But it still gave me the same issue.
vendredi 10 mars 2023, 21:30
Uninstall the x86 Version in your x64 System
LiquidMX
samedi 11 mars 2023, 21:04
Same problem here
installed net7 but aqua installer x67 can't detect net7, So basicly i can not install update.
Please help
Win10 and i do not have x86 version of net 7
X299 TOMAHAWK AC
CPU: i9-10900X 4.8GHz 1.185V all Cores
Ram: Kingston 256GB 3200MHz
Cooling : Aquaero 6 XT Controller
Rad: 360 + 240 EK
GPU: ASUS RTX3090
PSU: Seasonic PX 1600
Jacob
dimanche 12 mars 2023, 00:57
Feedback from the forum, I am version 66. After upgrading to 67, the peripherals cannot read the aquaero temperature signal,
causing the flow meter to run at full speed. In addition, the version display is still version 66.
I hope it can be replaced by an updated version, thank you. :)
-----------------------------------------------------------------------------------update>
I finally slowly know how to install the new version of AS, you must completely remove the old version including all configuration files,
otherwise you will encounter unexpected errors~! I upgraded from version 57 to version 66, and from version 66 to version 67.
I encountered the problem that the data of the calitemp temperature sensor could not be read. It can be restored to normal after completely removing it and reinstalling it. :)
Ce message a été modifié 2 fois. Dernière modification effectuée par "Jacob" (14 mars 2023, 10:35)
dimanche 12 mars 2023, 12:49
Uninstall all net 7 frameworks, net core, SDK.
reboot windows.
Install the correct desktop net 7 version.
Try install the aquasuite. These problems occur when you have a misconfigured window.
LiquidMX
dimanche 12 mars 2023, 20:52
reboot windows.
unfortunatelly this didn't work at all for me , tested 3 times with same conclusion, installer cannot see .NET 7.0.3 installed .
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
mditsch
lundi 13 mars 2023, 06:17
reboot windows.
which result do you get when doing that:
lundi 13 mars 2023, 09:51
We have updated the installer today.
There is now an option to ignore the Net Runtime check and install anyway.
But the Net 7 Runtime is needed, without it the software will not run.
Methodical
mardi 14 mars 2023, 10:16
Anyone try this and been able to get things working correctly?
LiquidMX
mardi 14 mars 2023, 21:34
CMD results below
LiquidMX a envoyé l’image suivante :
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
LiquidMX
mardi 14 mars 2023, 22:38
Thanks for that, installation wen't without problems and whole aquasuite running smoothly.
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
Methodical
jeudi 16 mars 2023, 23:25
To confirm. Even though it was stated that Aquasuite would not run without the Net 7 Runtime, yours is working?
LiquidMX
dimanche 19 mars 2023, 16:42
look above (i included image stating that .NET 7 is installed), aquasuite have trouble detecting installaion of .NET7
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
