• 10.10.2026, 10:36
Seanimus
EK-Loop D5 G3 PWM Motor to Aquaero 6
mardi 4 avril 2023, 01:12
Hello,
I installed 2x D5 G3 PWM and connected the PWM Fan cable to 2 different Aquaero 6.
GPU Pump shows in Fans. I named it as GPU Pump, and shows as Connected with 4807 RPM in picture below.
[img]https://ekwb.zendesk.com/attachments/token/pCxMBtOxK0CljAnbn62epr2tF/?name=mceclip0.png[/img]
But CPU Pump shows as not connected. But it will read the RPM fine.
Tried the 3rd port and same thing.
[img]https://ekwb.zendesk.com/attachments/token/V5WYW1XoUREPvqrAX11wuQ2tn/?name=mceclip2.png[/img]
Both Fan Settings are:
[img]https://ekwb.zendesk.com/attachments/token/2MjMJRvIysyqAkd4NHi1Up5e5/?name=mceclip1.png[/img]
Any help is appreciated.
Thanks.
mardi 4 avril 2023, 07:18
Make screenshots from complete aquasuite window. Fan page (each fan select) and Controller Page.
Seanimus
mardi 4 avril 2023, 19:07
Sorry had to setup onedrive for shareable photos.
This is my GPU Aquaero Setup.
I can see the pump as Connected and named it as GPU Pump, and Max RPM as 5000. PWM Setting in Advanced.
https://1drv.ms/i/s!AlrCj4uhKYB6gv8VZmHSvokr89dLzA?e=JE0wzA
This is my CPU Aquaero Setup. It says the Fan is not connected.
https://1drv.ms/i/s!AlrCj4uhKYB6gv8XwvcitmZz1kYiXg?e=osd9Oe
Both Aquaero its connected to Port 3. And both have Max RPM set as 5000 and as PWM (not power or speed)
I have not setup curve controller as yet. But if there is anything special I need to do for a Pump versus Fan, please let me know.
I tried inserting image, but it didn't show me picture in Preview. Instead did Hyperlink (one drive-shareable link).
Thanks for your help.
[Edit]:
I setup GPU Curve for Pump and it works and is significantly quieter.
https://1drv.ms/i/s!AlrCj4uhKYB6gv8ZeUv6e3s-sIRrrw?e=5Ogg3x
[Edit Edit]
I setup a CPU Curve for Pump to see what would happen and it actually worked, and RPM dropped (quieter).
https://1drv.ms/i/s!AlrCj4uhKYB6gv8a1-4UD3in4d8qtg?e=pcotfN
Went back to Fan Settings, and now it shows. Looks like it jump started/fixed something in software.
https://1drv.ms/i/s!AlrCj4uhKYB6gv8bhLknTZZ_vvdNeQ?e=VajPze
We can close this thread as Resolved.
Ce message a été modifié 4 fois. Dernière modification effectuée par "Seanimus" (4 avril 2023, 23:05)
mardi 4 avril 2023, 23:06
read the yellow message!
you have to assign a controller to this output. Read the manual, everything is explained.
Seanimus
mercredi 5 avril 2023, 17:49
Thank you..
Curve Controller was setup for GPU Aquaero on that port from previous build in 2016.
But it did not activate because Min Temp was 27C and actual GPU temp was lower. Changed that to 20C (in above post).
And should have read the yellow message carefully on the CPU Aquaero in this build, which did not have a curve controller.
I am good now. Need a refresher course every 5 years.
