• 13.11.2026, 10:24
Tanquen
Aquacomputer cuplex kryos Next - Work with AM5? - Offset bracket?
mercredi 3 mai 2023, 18:40
I don't think the Aquacomputer cuplex kryos Next AM4 / 3000 uses a backplate so it should be good for AM5 boards too?
Also, does the "Aquacomputer conversion kit socket AM4 / 3000 for cuplex kryos NEXT" offset bracket still make sense for the AMD 7000 CPUs? I would not think it would matter as long as the water block is in full contact with the CPUs heat spreader.
https://www.aquatuning.us/water-cooling/…c-glass-version
Ce message a été modifié 1 fois. Dernière modification effectuée par "Tanquen" (3 mai 2023, 18:41)
Tanquen
jeudi 25 mai 2023, 02:23
It worked on the new AM5 Board and I used the offset bracket to center the block on the CPU.
