• 17.11.2026, 01:11
Wazzzap
Control fans via high flow NEXT?
dimanche 23 juillet 2023, 18:29
Greetings! I recently purchased HFN to my custom loop. I'm wondering if I can control the fans connected to my motherbord in aquasuite? I want them to run based on the HFN temp sensor. I have no OCTO or similar unit and if it can be avoided, I would be really happy.
Remayz
dimanche 23 juillet 2023, 21:04
nop.Aquasuite only controls aquacomputer controllers.
exploiteddna
lundi 7 août 2023, 07:35
you will need to get yourself a quadro, octo, or aquaero. or you could use a D5 NEXT pump and connect your fans into the fan port on the pump, which links to aquasuite. there may be other ways to achieve this (i.e. other pieces of hardware that i havent mentioned here) .. but ultimately unless you have an aquacomputer device that connects to your system via USB, then it cant be controlled by aquasuite. aquasuite only reads from aquacomputer devices connected via USB (afaik)
