• 13.11.2026, 19:13
stu_allen
0.6l /min
dimanche 30 janvier 2005, 22:45
Is this a good or bad flow rate?
Ive got a cuplex pro cpu block, twinplex chipset block, 2x aquagrafx 6800blocks, 2x Aquadrives, a flowsensor (Obviously!) an airplex evo 360 and an aquastream pump at 70hz (it goes a bit mad at 74 and reports Short Circuit!) and an aquatube res in the loop.
The order of components is:
res-pump->rad->aquadrive1->aquadrive2->cpu->chipset->flowsensor->gpu1->gpu2->res
Ive got 2 more aquadrives to put in once the drives arrive.
pharao
Re: 0.6l /min
dimanche 30 janvier 2005, 23:18
stu_allen
Re: 0.6l /min
dimanche 30 janvier 2005, 23:20
oops, missed that one!
I guess its ok then, although its lower than i was hoping for. Should have gone for the cuplex Evo rather than the pro i reckon
kampfsau
Re: 0.6l /min
dimanche 30 janvier 2005, 23:24
well that always depends on your preferences ;)
i´d always choose the pro over the evo since i´m a fan of a sleek design - personally i think the evo is way too bulky
temps should be quite ok with the pro at that rate...
