• 01.11.2026, 01:05
smanet
Reconditioning old aquaero XT
jeudi 7 septembre 2023, 14:22
I could get a pair of XTs, a 5 and a 6, and I'd like to them to back to work in a brilliant manner.
Beside getting some some spare (I need the passive heatsink for a5 ), cleanin all the contacts... the two displays need more attention.
I'd normally buy a new one, but it seem impossibile to find.
So... One is glued really loosely, and the other seems to have too much glue, so I'll have to try to clean it as much as possibile.
Any ideas of what kind of glue is that, so I can detach all parts, clean and put it back together?
Or, better, where can I find a new display...?
Hufeisen
jeudi 7 septembre 2023, 18:24
You can find replacement displays in the shop.
Replacement display for aquaero 5/6 XT
Replacement display for aquaero 5/6 PRO
Or you can remove the display and use it as Aquaero LT Version.
smanet
vendredi 8 septembre 2023, 12:34
Thanks, I know about that possibility, but I'd like to have it as an XT and, if necessary, flash it as LT slave for the A6 .
I'd need this part: Aquacomputer Replacement Front in New Design for Aquaero 5 and 6 XT (Blue LEDs) AQ-53208 (performance-pcs.com)
but the store is in US... customs rise too much the price :(
Top_Nurse
jeudi 14 septembre 2023, 07:48
To clean your connections (terminals & cables) the best stuff on the planet is DeoxIT D5. You can get it at any electronics supplier as well as Amazon. I love the stuff! :D
Discussions similaires
