• 30.10.2026, 03:18
Recoil
Change Up Time From Seconds to Hours
vendredi 8 septembre 2023, 07:06
Hi Folks,
In Aquasuite when I try to create a new item and add the data source for "Up Time" it is displayed in seconds, could this be changed to hours?
Time is another one that is set to 24 hours instead of 12 hours, can this data sources be changed? Thanks.
vendredi 8 septembre 2023, 13:39
Uptime may be converted to decimal hours by making a Virtual Sensor (hours_up.jpg)
The 24 hour, hour result may be converted to the 12 hour format by making a Virtual Sensor (12_hour.jpg)
Recoil
vendredi 8 septembre 2023, 18:50
Thank you! I appreciate your help.
Recoil
vendredi 8 septembre 2023, 19:40
Could I ask you if you could share your Coolant/Ambient delta? Thank you once more.
vendredi 8 septembre 2023, 23:28
It's basic (delta.jpg)
Recoil
lundi 11 septembre 2023, 16:18
Thank you very much, trying to see as many examples as possible, I wish it was easier to find more info or templates to use with virtual sensors.
lundi 11 septembre 2023, 16:46
You may find some of KayBee Tech's videos helpful.
https://www.youtube.com/@KayBeeTech/videos
Recoil
lundi 11 septembre 2023, 21:43
Thank you, that helps :)
Discussions similaires
