• 12.11.2026, 19:45
frogs114
Octo + Next USB overcurrent
mercredi 10 janvier 2024, 17:36
I am building a new system with octo + next and when I plug one or both devices into the usb 2.0 header, my computer will not start due to a usb overcurrent. If I flip them the RGB flashes red and the computer won’t start. I’ve purchased a powered USB 2.0 splitter and it does the exact same thing. I’m not entirely sure what to do minus just removing the either one completely.
Ce message a été modifié 1 fois. Dernière modification effectuée par "frogs114" (10 janvier 2024, 20:20)
MaxTwister
mercredi 10 janvier 2024, 19:18
you have connect a 5 volt molex to the octo ??
:D
On CachyOS
frogs114
mercredi 10 janvier 2024, 19:25
Yes. It’s connected via Molex. There are no obstructions or bent pins in any of the USB sockets and I just can’t figure out what’s going on.
MaxTwister
mercredi 10 janvier 2024, 19:49
maybe a problem with the power supply on the 5 volt
:D
On CachyOS
frogs114
mercredi 10 janvier 2024, 20:12
So what do I do here? It happens if either one is plugged in.
MaxTwister
mercredi 10 janvier 2024, 20:53
maybe your power supply pushes only 4,37 volt its not enough
:D
On CachyOS
Bartdude
jeudi 11 janvier 2024, 08:50
What motherboard do you have and are there any bios updates for it?
PvF
jeudi 11 janvier 2024, 09:55
probably not, but perhaps plugged in the wrong way round?
jeudi 11 janvier 2024, 18:27
It is also easy to plug in the USB2.0 header offset by 1 pin.
