• 07.10.2026, 11:39
Makse
Fan curve mystery Octo
mercredi 31 janvier 2024, 21:39
Hello
I just got an Octo, and installed Aquasuite.
Started to play around with fan curves. But something is very wrong.
Please see attached pictures.
If I set the Fan 1 curve to automatic (Or set it manually) and then shift to Fan 2, and change/touch just one point, the Fan 1 curve gets totaly messed up. (Picture 3)
Whats the problem?
Thank you in advance.
Makse a envoyé les images :
jeudi 1 février 2024, 07:25
Click Automatic Settings to set up the curve and move the slider.
Makse
jeudi 1 février 2024, 12:28
Hello Sebastian
That is exactly what i did in picture 1. Then I chose Fan 2 (Picture 2), made a small change and jumped back to Fan1 (Picture 3)
jeudi 1 février 2024, 13:07
This is a display error. If this occurs, you must click on another fan and then switch back again.
In the next aquadsuite update this issue is fixed.
Makse
jeudi 1 février 2024, 17:17
Yes, I finaly figured it out late last night.
Thank you for your support.
Discussions similaires
