• 30.09.2026, 16:37
Canard_Coincoin
Pump speed based on virtual sensor
jeudi 29 février 2024, 15:46
Hi everyone,
I am using aquasuit X.78 with an octo and I am wondering how to have my pump speed based on CPU + GPU temp.
I have created a virtual sensor summing these two values but when I go to fan settings, controler source can only use on of the 4 physical sensors.
Any help ?
Thanks :thumbsup:
Remayz
jeudi 29 février 2024, 18:57
you need to go to the Octo Sensors page.
Select any of the software sensors available, and click data source.
On the list, in the "Data from Aquacomputer Service", you have your virtual sensors.
Once the Octo software sensor is attributed to the virtual sensor of your choice, you can use it for fan control
Canard_Coincoin
vendredi 1 mars 2024, 13:09
Hi, thanks for your answer.
This is what I did but unfortunately I have only physical sensors when I go in fans => controler source => select data source
Remayz
vendredi 1 mars 2024, 18:26
you have to add first your virtual sensor there, in a software sensor slot (clicking data source):
Once you added it, it will appear in fans => controler source => select data source
is that what you did ?
PvF
vendredi 1 mars 2024, 18:28
You have to do it as Remayz wrote and import the virt. sensor into the Octo first.
Octo -> Sensors Page -> one of the free soft. Sensors and use your virt. Sensor as data source.
You can then use this imported value as a data source for the control in the Octo.
Canard_Coincoin
vendredi 1 mars 2024, 19:00
Am I crazy ??? 8|
I have the sensor declared in soft sensors of the octo and the value is correctly calculated/displayed.
But when I go in the fan speed setup I have only physical sensors :
PvF
vendredi 1 mars 2024, 19:58
You must add the unit "°C" for your virtual software sensor (CPU + GPU temp.) in the Playground, otherwise it will not work.
Only Temperatures will work in the Octo :-)
In this example, I have to convert a value that I enter via "Inputs" in "%" 1:1 into a temperature in order to control the speed of my D5 Next
Ce message a été modifié 1 fois. Dernière modification effectuée par "PvF" (1 mars 2024, 20:07)
Canard_Coincoin
vendredi 1 mars 2024, 20:41
Well done PvF !
It was that.
Thanks everyone for your help. :)
