• 23.11.2026, 01:22
JonnyK
Is there a way to remove quality control markings or rotate the pump casing?
mercredi 27 mars 2024, 19:46
My D5 Next with Ultitube arrived with a prominent quality control stamp on the front of the pump. Can this be removed, or can the casing around the pump be rotated to hide it? I don't want to rotate the whole pump because that would rotate the control unit, just the casing. So far I've been unsuccessful.
Thanks.
JonnyK a envoyé le fichier suivant :
Mr. Krabs
mercredi 27 mars 2024, 20:04
Try isopropanol. Maybe it works. Never use Aceton or other aggressive chemicals. In some cases a normal rubber works fine.
Noname21
mercredi 27 mars 2024, 20:09
Hi JonnyK
Did you buy the pump new or second-hand?
If the pump is new, I would write to Aquacomputer. They will certainly be able to help you.
JonnyK
mercredi 27 mars 2024, 20:34
This is brand new right out of the box, Ultitube Pro with D5 Next. I splurged.
jeudi 28 mars 2024, 15:28
Vinyl Wrap?
Ushavilash
lundi 1 avril 2024, 12:31
Hey hi, you may need to contact the manufacturer for specific instructions on removing the quality control stamp or rotating the casing around the pump without affecting the control unit.
Discussions similaires
