• 06.10.2026, 08:53
softlion
Issue with Aquasuite and Aquaero 6
lundi 22 juillet 2024, 18:00
Since a couple of days now, the aquaero is loosing its configuration and uses an old configuration instead.
That happens when it switches Global Profiles from 1 to 2, then back to 1.
All settings changes are forgot.
When you change a settings while profile 1 is active, you save, but you don't save it as "Profile 1" explicitely.
Does that should work ?
Because it's not.
PvF
mardi 23 juillet 2024, 05:28
You must explicitly save your changes under the profile (e.g. Profile 1). Otherwise the changes made will be lost when you switch profiles (and only then).
It's always been that way (at least as long as I've been using the Aquasuite) and hasn't changed just a few days ago :)
Discussions similaires
