• 02.10.2026, 18:19
Longfellow78
No Aquaservice - totally forgotten everything about this software. HELP?!
lundi 5 août 2024, 18:46
I built a PC about 3 years ago on Windows 10 using the aquacomputer quadro. It's a pretty complicated build with a water temp sensor in the Res with the D5 pump.
I really can't remember anything about how to set it up or how I built it.
I noticed that the computer was louder than it used to be so wanted to adjust the fans and pump and I see I can't login to the aqua computer service. I can see it still responds to temp changes and controls the fan and pump, I presume from the settings stored on the hardware, but it says no connection to aqua computer service and it's not running and I can't make it run.
Is it something to do with the update to windows 11? my coolant temp and air temp still work, but none of the GPU or CPU sensors work. My software ran out in 2022. I'm not going to buy the update because removing support from hardware without paying for it is a scummy move.
Can anyone advise please?
Thanks.
lundi 5 août 2024, 19:26
Simply run the aquasuite setup from the website and select the version which does not require to extend the update service.
Tattude69
lundi 19 août 2024, 14:09
I have had Aquaservices fail to launch on start up 3 or 4 times since last windows update. [soft sensors not reporting values] In Aqua suite i restart with admin permissions and then restart computer and all soft sensors reappear. Never had this problem until recently been running an OCTO for a few years with no issues. Last week i installed a D5 Next which updated Aquasuite but then an hour later windows updated so i am not sure which is causing the problem Same problem today when i started computer. I have changed the delay time in settings for Aquasuite to 15 seconds and that has seemed to fix the problem so far
Ce message a été modifié 2 fois. Dernière modification effectuée par "Tattude69" (22 août 2024, 13:38)
