• 03.10.2026, 05:59
Teasuti
Leakshield: manually open the venting valves to help with draining the loop?
mardi 13 août 2024, 14:10
Hi guys,
Is there any way, button, script or diagnostic command to open the vents up and leave them open in the device?
The Release function only leaves it open briefly, then it shuts off after a few seconds.
I'd wish to set whether I'd like to seal the system or leave it open.
All that in the hope that I wouldn't need to take things apart to get air in when I want to drain the loop.
I have this device that manages air pressure, so why can't I just use it to let air in and let the fluid drain out? :)
Cheers!
Ce message a été modifié 2 fois. Dernière modification effectuée par "Teasuti" (13 août 2024, 14:25)
Teasuti
jeudi 15 août 2024, 21:46
up
vendredi 16 août 2024, 05:18
I am not aware of any way to do that, and I don't know if there is any reason that valve could not be left in the open position. When I want to drain my loop I just unscrew the Leakshield from the Ultitube then open my drain valve.
