• 02.10.2026, 20:03
gufau
Hight flow nextand alarm
lundi 11 novembre 2024, 13:43
Hello,
I just acquired a Hight Flow Next and I am very satisfied.
One point however, when I stop my PC, the alarm is triggered and even with the extinguished PC, the alarm continues to ring ...
I have to turn off the food so that it stops.
I think there must be something to do !
Second point, I have the impression that the profile that I created with for example the "Invert" display did not save in the restart.
Thank you for your help,
Guy
lundi 11 novembre 2024, 21:46
A screenshot of your alarm page may be revealing (i.e.Alarms.jpg)
Is your USB connection to the high flow next connected to a USB port on your motherboard?
gufau
mardi 12 novembre 2024, 14:56
Hello,
Thank you for answer
I'l make a sceen this evening
For the USB connection, its an USB port on the motherboard
mardi 12 novembre 2024, 16:23
I would assume that the fault lies more in the standby settings. Presumably the highflow NEXT does not recognize that the PC is shut down or in standby, so it warns of low flow. This can be found under System/Standby Settings.
gufau
mardi 12 novembre 2024, 16:31
"This can be found under System/Standby Settings.", on the Hight Flow ?
gufau
mardi 12 novembre 2024, 16:32
"This can be found under System/Standby Settings.", on the Hight Flow setting ?
mardi 12 novembre 2024, 16:33
Of course, that's what we're talking about.
gufau
mardi 12 novembre 2024, 16:46
Yes, obviously... There is also this kind of item in the Windows settings!
mardi 12 novembre 2024, 16:49
My mistake, I thought it was obvious that when talking about the highflow NEXT and its settings, you also refer to the Aquasuite and not to Windows settings.
gufau
mardi 12 novembre 2024, 18:04
Thanks all,i suceeded :)
