• 30.09.2026, 17:24
ironcobra80
D5 Next display issue
dimanche 24 novembre 2024, 17:01
I have a d5 next pump/res combo, high flow 2 and an octo running all my fans. I am trying to get the d5 display to show my flow rate from the high flow 2. Under the sensor tab for the D5 i can add the hf2 to the sensors but the display tab all of the options are showing no flow rate.
lundi 25 novembre 2024, 07:18
This Display Show only a flow when you connect a flow sensor direct (fan-connector) to the pump.
ironcobra80
dimanche 15 décembre 2024, 18:19
Okay I did that and got it working only as a virtual sensor is this right? There is an option under menu for the high flow 2 but it doesnt show any data. And does the display on the D5 only show g/h and not g/m?
