• 22.11.2026, 23:09
shteud
Aquabus cable pinout (and small advice about aquero) needed
mardi 31 décembre 2024, 13:09
Hello all!
I need to find a pinout to make this cable
https://shop.aquacomputer.de/Monitoring-…NEXT::3487.html
I have an RGBpx cable and plan to use these small connectors to make normal cable to connect OCTO 8 and Farbwerk 360 to Aquero 5xt. I just need to find a legit pinout for this cable.
Also, do I get the right to make OCTO and Farbwerk work with 5XT I need first to connect them via USB change to slave mod and only after that can I use them solely via Aquabus?
mardi 31 décembre 2024, 14:51
You can find the cable assignment in the instructions for the Aquaero and e.g. the Quadro under Support -> Downloads.
Re-flashing would only be necessary if you want to use a second Aquaero as a slave; this is not necessary for other devices with Aquabus. Nevertheless, the USB connection should always be connected, as not everything can be addressed via the Aquabus and the devices without USB cannot receive firmware updates.
shteud
vendredi 3 janvier 2025, 17:44
Yes some how forgot about manuals :)
Thx
