• 22.11.2026, 22:14
SgtSixpack
I want an additional temperature sensor in my loop so that I get a power disipated reading from my High Flow Next.
mardi 4 février 2025, 20:28
I've been looking at temperature sensors. I though it would be a plug/end stop rather than a pass through sensor. I've seen a plug type, just not aquacomputer. Is there a reason that the aquacomputer temperature sensors are pass-through and not plug type? Or could you put a plug on the end of one and put it on a blank port of a GPU waterblock for instance (I have a plugged port that gets sprayed directly on my GPU waterblock).Edit: I think I could easily add it to the inlet of my GPU, with the tube fitting on top (maybe not that easy as it means draining the loop again).
Ce message a été modifié 1 fois. Dernière modification effectuée par "SgtSixpack" (4 février 2025, 20:33)
mardi 4 février 2025, 22:16
In order to get an accurate dissipation number for the radiator, you should have the two temperature sensors close to the radiator inlet and outlet ports.
I don't believe it matters which sensor is at which end, the builtin calculator uses the absolute difference.
The high flow next has a temperature sensor internally, so just one additional sensor is needed for the external temperature port on the high flow next.
Any one of these three should do. (SENSORS)
