• 15.11.2026, 18:40
KTUS
Add new line to sensor name
jeudi 13 février 2025, 17:42
In Aquasuite I have some sensor names that are long and don't fit well in the gauge representation of the sensor. For example, I have a sensor named High Flow Water Temp. On the gauge the name goes over the ring on both ends. How can I add a new line character to the name so that the name changes from:
to
High Flow
Water Temp
Yes I can make the font smaller, but then I can't read it well.
vendredi 14 février 2025, 09:43
Check this video.
At first you disable the automatically generated name. Then you add a text block, remove its background, use
 as command for a new line in the name, set the text color to #FF04BAF0 (hex code with alpha and color) and move it to the desired position aftewards.
KTUS
vendredi 14 février 2025, 18:28
Thanks Shoggy. Got it to work.
