• 16.11.2026, 20:48
3dpro
Problem with Aquaero 6 LT with VPP Apex pump
vendredi 14 mars 2025, 16:15
Hi, I've been using Aquaero 6 LT as a standalone system with Alphacool VPP Apex pump. The pump is currently control by 100% preset controller.
There's some weird behavior with the pump.If I set Maximum Power at 100%, The output rotation speed will be 0 rpm.
But if I set the maximum power at 1.0%. The pump will be running near 100% and output the correct fan rotation speed
It's looking like the power is running in invert? Is there a way I can flip it? Here's also the advanced setting of the fan.
