• 11.11.2026, 12:54
BaconFox
Highflow Next sensor air ingress with Leakshield
jeudi 20 mars 2025, 23:26
Hello.
I've noticed a large amount of air bubbles coming immediately downstream of my Highflow Next flow sensor on pump startup. This happens after leaving the computer/pump off overnight but still under vacuum from the Leakshield, typically 400mb neg. I did some testing of different components and it appears that while the Highflow Next is not leaking water, it does allow air ingress under vacuum.
Is this typical for the Highflow Next or do I have a faulty unit? I'd be disappointed if it's inherently incompatible with the Leakshield as I like the sensors it provides.
Thanks for your input!
Primary components:
  • Ultitube 100
  • Leakshield
  • D5 Next PumpAlphacool Apex AM5 waterblock
  • 2x Corsair 360mm radiators
  • Primochill Primoflex Advanced LRT tubing, 3/8ID 5/8OD
