• 21.11.2026, 01:25
cwestbrook
Leakshield on ULTITUBE D5 50 PRO reservoir with D5 NEXT pump?
mardi 15 avril 2025, 18:06
Will the Leakshield work on the Ulititube D5 50 PRO reservoir with D5 NEXT pump? Didn't know if it would or not, since it's so small.
mercredi 16 avril 2025, 14:09
It won't work because the air pocket in the reservoir will be too small.
Well, you could run it that way but you will very likely get a lot of false alarms and the vaccum pump has to run more often to maintain the negative pressure.
I wouldn't do it. You'll just get upset about it... ;)
