• 14.11.2026, 20:13
n3rz001
run 2 quadro with usb is it possible?
dimanche 8 juin 2025, 17:22
Good afternoon,
I own a quadro controller that work great and im re ally happy about what it does and performance but here the problem:
I have 4 groups of fans and a pump , i planning to use aquasuite to regulate all of them (now i wish i would buy a Octo) can i connect another quadro to the motherboard to add the extra fans ? Or they re go in conflict with each other? If someone have a better solution please let me know.
Thank you
Remayz
dimanche 8 juin 2025, 20:37
it will work fine. you'll only have to play with software sensors to use like the temp sensors of your current one to drive fans or pump on the other.
dimanche 8 juin 2025, 20:59
Yes you can connect another Quadro to a motherboard USB port (while powered down, of course). After you connect it, when you boot into Windows and Aquasuite opens, you will see both Quadros in the left side panel. They will operate independently - no conflicts. There are some advantages to having 2 x Quadros versus 1 x Octo. You will have 8 x temp sensor headers instead of 4, and 2 x flow sensor headers instead of 1. You will also be spreading the fan load across 2 x Molex power connectors instead of 1.
You could avoid adding the second Quadro if you group more fans together with a Splitty or some other PWM splitter. Grouped fans will all get the same PWM signal, so they will run at the same speed (if they are the same model fans). Whether this is a problem depends on how granular you want your fan speed control to be.
You didn’t specify what pump you have. If it’s a D5 Next, you can control the speed in Aquasuite. If it has a PWM cable for speed control, you could connect it to a mobo PWM port instead of the Quadro and leave it at a fixed speed. Varying pump speed does not really do much, and it's harder on the pump. To find the minimum speed, connect the pump PWM cable to a Quadro PWM port, set it for 100%, then start reducing the speed while monitoring temps. You will find that at some point, temps will start to increase, probably when the speed gets down to 25 to 35%. Once you find this point, increase it a bit and leave it. Then, move the pump PWM cable to a mobo PWM header, and set it for the same speed in the BIOS. Your pump will now operate just above the minimum speed necessary to sustain optimal temperatures while minimizing power consumption, noise, and waste heat, and it's not using up a Quadro PWM port.
n3rz001
lundi 9 juin 2025, 02:40
Thank you very much for your help,
so yes i have a pump with pmw to regulate the speed, yeah i could connect to pump header to Mb but i prefer have it on quadro and monitor/ control with it, also i planning to get a flow sensor (another pmw connector) .As you said i have another group of fan that need to run separately because they have different speed but also they use 0.7A each fan , so i need to connect them in another port . i believe quadro header can manage 25w and 2A, but i can be wrong.
Remayz
lundi 9 juin 2025, 03:23
the aquacomputer flow sensors go on a dedicated header on the Quadro, so it won't take a PWM header
n3rz001
lundi 9 juin 2025, 08:45
Yeah i m not planning to buy the aquacomputer one , it is ugly, i will take another brand.
mardi 10 juin 2025, 03:06
Which flow sensor are you planning to get? The Quadro and Octo do have a Flow Sensor header, but AFAIK, they can display the flow rate, but that is all they can do. I think control sources for fans in the Target Temp and Curve Controller modes can only be temperatures. I guess in the Playground you could make a virtual sensor with the flow rate as the input, scale it, and make the output unit be °C. Then you could control the fan speed with the flow rate, but I don't think it makes any sense to do this.
Bartdude
mardi 10 juin 2025, 08:22
Wow if you only want a flow meter to look nice then.... but if you want one to accurately measure flow then the HFN2 is the way to go. check this this if you want an accurate flow reading
mardi 10 juin 2025, 16:46
I read that Igor's Lab article years ago and was amazed at how bad the Thermaltake and Barrowch flow meters are. It was written 5 years ago. Since then, Thermaltake released the TF2 and Barrowch has released the FBFT07 and FBFT08. I wonder if any of these new models are more accurate than the models Igor's Lab tested. Koolance also makes a BUNCH of them and released the DCB-FMTP01 display unit in 2024. I suspect the Koolance products are accurate, but since I use Aquasuite to monitor and control my cooling loop components, I see no reason to use anything other than an Aquacomputer flow sensor.
n3rz001
mardi 10 juin 2025, 20:47
Im planning to get the alphacool one with the spinning wheel and the rgb, i don t need a super accurate one , i will use it as alarm if the pump fail and stop to works. For now i have 2 sensors and 5 fans connections i m still evaluate if i ll buy another quadro or i just put the pump at 60% fixed but i really appreciate your feedback and help you re amazing guys
Bartdude
mercredi 11 juin 2025, 07:22
Personally watercooling is for the performance benefit and keeping my components cooler than they were on air. Just having my GFX card run at 50c max under load rather than 70/80c or more on air is a massive difference, the aesthetic side I see as a bonus and is secondary to everything else.
Problem is most manufactures look at the aesthetics first and performance comes second, more interested in adding fancy RGB etc. Not that you can buy many components that aren't adorned with it now but that's where we are.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Bartdude" (11 juin 2025, 07:31)
mercredi 11 juin 2025, 11:25
Just a quick note if the idea is to somehow connect a different flow sensor to the flow port: QUADRO only supports the impulse rate conversions of our sensors. It is not possible to use a custom value.
n3rz001
jeudi 12 juin 2025, 13:17
Ok good to know thank you
n3rz001
samedi 14 juin 2025, 21:34
Btw temps looks fine i believe with ff14 and helldiver2 opened
n3rz001 a envoyé le fichier suivant :
