• 16.11.2026, 01:56
pawelzby
OCTO Fan Output Smoothing or PID Control
vendredi 4 juillet 2025, 04:57
I'm getting set up with the OCTO in the Aquasuite software and I don't see an option for fan RPM output smoothing, signal averaging, or controller PID tuning. Specifically, I'm looking to reduce the rate of output ramp up/down when my CPU temp is acting erratic. Ideally, I'd like for this to happen over the course of ~10 secs rather than instantly. I have seen this feature in other places, but can't find it in aquasuite.
Does it exist? Am I not looking in the right place?
Thanks,
-Pawel
vendredi 4 juillet 2025, 15:00
Use the target temperature control for the fan channel and set the controller speed to user defined. This way you can adjust the PID values.
You could also use a virtual software sensor in the playground where you apply some filters to the CPU temperature. You would then use this virtual software sensor as the data source in the the fan controller settings.
