• 19.05.2026, 15:05
vinnybear
no longer seeing CPU temp via octo Aqua computer harware monitor
vendredi 19 septembre 2025, 00:40
hello,
since yesterday I can no longer see the CPU temp and therefor have lost the ability to run custom fan curves based on CPU temp.
I only see CPU load
any help would be appreciated
BR
Vincent
running an octo from years ago
windows 11 on a non compatible cpu : 12th Gen Intel(R) Core(TM) i7-12700K asus mother board TUF gaming z690-plus wifi
vinnybear a envoyé le fichier suivant :
  • octo.jpg (62,98 kB - téléchargé 52 fois - Dernier téléchargement : 14 mai 2026, 23:57)
Ce message a été modifié 2 fois. Dernière modification effectuée par "vinnybear" (20 septembre 2025, 00:08)
dfmastin
vendredi 19 septembre 2025, 22:24
same problem
SaiBork
samedi 20 septembre 2025, 09:10
See the last couple pages in the "New: aquasuite X" post.
New: aquasuite X
That's probably why you're having the issues.
Remayz
samedi 20 septembre 2025, 16:03
just a side note, your CPU is compatible with windows 11. the installer may flag it as incompatible if your UEFI is not set right, like TPM and/or secure boot disabled.
vinnybear
dimanche 21 septembre 2025, 04:10
found the issue seems windows defender is not liking Aquasuite.exe and the other .exe . it thinks they are trojans.
told it to ignore
dimanche 21 septembre 2025, 05:42
Lots of people are having problems with Winring0, which Aquacomputer has apparently repackaged into the AquacomputerService.sys driver in the X.83 update. This driver code is getting flagged by Windows Defender as a Severe Threat because Winring0 is an unsigned Kernel-mode driver. Aquasuite uses this driver for all of its hardware monitoring. There is a thread about it on the English forum HERE and a bunch of posts about it in the New aquasuite X thread starting HERE. There are more posts about this problem in the German forums HERE and HERE. Microsoft cracked down on this unsigned Kernel-mode driver back in April, then backed off because it is used in multiple programs. In March, Aquacomputer said they were working on writing their own Kernel-mode driver and getting it certified by Microsoft. This still has not happened and now Microsoft Defender is flagging it again.
Discussions similaires
