• 23.11.2026, 08:41
Oceanlab
mercredi 15 octobre 2025, 21:25
Initially, only the version shown will be available, either with the latch facing the PCB or away from it
Tell me please
It is planned to purchase the asus rog astral 5090 liquid edition
Standard cables from the seasonic power supply unit with direct connectors will be used for connection.
Which version of your product is suitable for me?
Thanks for the answer!
vyoh
dimanche 19 octobre 2025, 19:24
Will you be shipping this outside of Germany ? I am pretty scared of using my 5090 lately with the amount of melted cables i have seen on social media lately, so I really hope I can get my hands on this asap so I can go back to enjoying gaming
mardi 21 octobre 2025, 09:24
You will need the the variant with the latch pointing towards the PCB.
We ship worldwide, with a few exceptions.
Can you make sure that ampinel works for 5090 founders edition or any founders edition card? The recent connectors for founders edition are angled and not 90 degree
This will not work with the current version, and you would have to use an extension cable. At this point, I cannot say whether there will be an adapted version available at a later date.
Maybe it is a stupid question, but since the output per pin currents regulated and monitored is there a good reason not to using a short extension cable (in a space restricted sff build) to connect it to the GPU?
It is possible to use an extension cable but you have to be aware that additional contact transitions can have a further negative impact on the current flow.
jwingy
jeudi 23 octobre 2025, 01:53
As I understand it, some sort of extension cable would be required for this to work with a 5090 FE? If so, is there any specific type of cable you would recommend?
On the point of using an extension cable, it was said that: "...you have to be aware that
current flow." What does this mean / what are the implications of this exactly for a lay person? Thanks!
Asphroxia
samedi 25 octobre 2025, 08:50
Just wanted to drop in and show my support for this product! very excited to finally have a proper solution compared to the other solutions before from other brands.
Also wanted to share my interest in the white model!
vyoh
lundi 27 octobre 2025, 21:25
Do you know if this will be compatible with the MSI 5090 Suprim (the air cooled one), and which orientation I would need?
shinazero
mercredi 29 octobre 2025, 08:23
have the same question.
Railgun
mercredi 29 octobre 2025, 12:45
As November is in a couple of days, and this was indicated to ship mid-Nov, when can we expect to have it available for pre-order?
For every interconnect, there's some loss/added resistance to the whole chain. The extension is required due to how the socket exists on the FE. Any appropriate cable should work. it's literally just an extension cable. Though I'd not use one.
YMMV.
TechBaguette
jeudi 30 octobre 2025, 21:18
I'm very interested in that device.
But most of the time, that kind of thing isn't designed for compatibility with riser in mind (which is too bad as riser avoid to put too much weight on motherboard port).
For exemple, I use the Cooler Master Vertical Graphics Card Holder Kit V3. Like most of riser holder, there is a vertical plate behind the graphic card.
On this model, between the verge of the 12VHPWR plug of the graphic card and the edge of the vertical plate of the holder, there is a thickness of nearly 2,5 cm.
it means there should be 2,5cm between the 2 connectors of the AMPINEL to make the device compatible (for exemple, it's impossible to use the WireView Pro 2).
Do you think it's possible with the AMPINEL?
Also i'm very interested in the white version to match the color of my rig, or even a silver one.
Kazdi
Load balancing
vendredi 31 octobre 2025, 00:18
Your competition just unveiled their new product and in the video they say, that they decided against active load balancing because they dont know what is going to happen if you push higher current through pin that has higher resistance. What do you think about that?
RE: Load balancing
vendredi 31 octobre 2025, 23:26
What is going to happen if you push more current through the conductor that has a higher resistance is not a mystery. More current through a higher resistance means more voltage drop across that resistance, which results in more power being dissipated as heat. I don’t think the Ampinel works that way.
If one circuit path has a higher resistance, less current will flow through it. The Ampinel does not try to balance the current flowing through the 6 conductors by forcing more current through the high resistance path. Doing that would cause more heat to be generated, which further increases the resistance of the contact. A feedback loop is formed that results in a melted connector. My understanding is that the Ampinel adjusts the voltage drop across the total resistance in each circuit path. If 1 conductor has a higher resistance due to poor contact alignment, oxidation, or whatever reason, less current will flow through that conductor, not more, because V = I2R, so if the resistance is higher, the current must be reduced to keep the voltage drop the same. If the resistance is so high that the Ampinel cannot compensate for it, the Protection mechanisms are activated. That is how I think it works after reading Igor's Lab articles about the Ampinel. If I am wrong, perhaps someone from Aquacomputer will jump in here and clarify.
I am curious about this other new product. Can you provide a link to the video you mentioned?
Kazdi
RE: RE: Load balancing
samedi 1 novembre 2025, 14:13
https://youtu.be/IY5Ak33rPg8?t=1096
dimanche 2 novembre 2025, 04:03
Oh OK you were referring to a product, that I am already aware of. I thought there was another player entering this market. He expresses concern that the Ampinel will push more current through a conductor/contact that already has a problematic resistance. According to Igor’s Lab, that is not what the Ampinel does. Igor says the Ampinel does not attempt to push the same amount of current through all 6 conductors. Instead, it attempts to make the voltage drop across the effective resistance of all 6 circuits be the same. He says it does this by slightly increasing the resistance of the other 5 current paths. This is the part I don't understand. If the Ampinel increases the resistance of the other 5 current paths, and the GPU power demand remains the same, then the amount of current that has to flow to deliver that power stays the same. If the resistance of the other 5 current paths is increased, then more current has to flow through the bad path. I am hoping someone from Aquacomputer, or another forum member can clarify this point for me.
Here is a quote from his article about this. I also provided the link so you can read it yourself if you like.
“Update: the load balancer does not arbitrarily change the current on a line but seeks the electrical operating point at which the voltage drops across all lines are as equal as possible. If a pin carries less current due to higher contact resistance, the system is initially unstable because the other five paths take on more load. If nothing were done, the difference would grow ever larger, and that is exactly what is observed in unbalanced connectors. In this situation the balancer does not try to actively load the weak pin more but reduces the dominance of the overloaded paths by slightly raising the effective resistance there. The total current remains almost constant, the source, that is the power supply or the GPU load request, determines it, but the voltage distribution at the connector becomes equalized. This electrically reintegrates the “bad” contact without necessarily requiring it to carry its full one sixth load. The system does not aim for equal current shares but for minimal voltage deviations, in other words a stable state of equal distribution.”
Igor’s Lab reviewed the Ampinel a few weeks ago. That review is HERE.
There was a lot of confusion about how the device works, so he did a follow-up article that goes through the whole 12VHWPR/12V2X6 connector saga, what Nvidia did (or more accurately did not do), what Asus did, what der8auer did, and what the Ampinel does. He compares the strategies of just monitoring the current versus actively controlling it. In part 4 of the follow-up article, he addresses the concern that is expressed in that video. Maybe the author of that video still does not understand how the Ampinel works, or maybe he does...
Here is a LINK to part 4 of Igor's Lab follow-up article.
Kazdi
dimanche 2 novembre 2025, 14:46
Thx for detailed response. I dont understand everything, but i read all what you said and the igors article and i believe all is good. Active load balancing seems like the way to go. Iam already on the list to get notified when ampinel is up for preorder. I just dont want my 5090 to burn :))
aquafan
mardi 4 novembre 2025, 15:04
Any word on pre-order or release? It's been bit quiet on that front
Railgun
mercredi 12 novembre 2025, 18:05
i'm guessing it was a bit of a premature announcement/ETA. Like all things seem to be these days, QC issues, manufacturing delays, or just too ambitious to timelines.
CornyOC
lundi 17 novembre 2025, 19:00
Is this going to release this year at all? I would like to see how it works as they claim per wire AMP regulation. Der8auer stated that they tried regulating AMPs with their product (Wireview Pro II) but they found it to be dodgy and very difficult to safely execute.
TaikoHax
mardi 25 novembre 2025, 10:15
Hi there!
I came from the depths of the internet to add a +1 if possible for the 5090 FE
Though a follow up question was going to be :
- if i bought a new PSU with a 12 pin connector could your product be added to that end of the cable run instead of the GPU side? (one assumes it will still detect if an individual pin is overheating since it's likely the increased temperature will be present through the entire length of the cable?
- the design you have now looks like it might fit the angled connector of a FE, but of course leave the unit protruding out at an angle - has that been your observation or have you not had a chance to test it?
- if push comes to shove I assume this could be connected in-line and whilst that would introduce two extra sets of 'breaks' in the cable, it would still function as intended (i.e. recognise if cable entering and exiting the unit was overheating?)
Very exciting product and I hope you will consider a solution that works for the FE version!
nebj00la
lundi 1 décembre 2025, 05:23
+1 for use with a 4090FE. Definitely interested in this product.
Naborabanne
samedi 6 décembre 2025, 20:13
Hello,
same question.
you've been talking about Ampinel for two months now.
When will it be released?
When will we be able to order it online?
