• 30.11.2026, 22:05
FancyScrubs
Windows 11 system interrupt
lundi 27 octobre 2025, 18:33
My current setup:
Quadro fan controller connected via internal USB
highflow next sensor in series with loop.
I am currently running the aquasuite software to manage my fan curves based on water temperature. I have read that it is possible to set your fan curves in the aquasuite software but then disable the system service.
My main issue is that there is a long system interrupt after landing on my desktop and sometimes after resuming from sleep. It's not terrible, but definitely annoying.
Is this accurate? Or does the aquasuite service need to be running to actively manage monitoring temp and fan ramp up.
Thank you!
Mark
mardi 28 octobre 2025, 06:37
The Quadro runs independently as long as all sensors used are directly connected. You only need the Aquasuite for the initial configuration. If you want to use the temperature sensors of the Highflow next, this is no longer possible, as these are connected via USB and therefore require the Aquasuite background service.
FancyScrubs
mardi 28 octobre 2025, 16:38
Ok, that makes sense. Thank you!
