• 30.11.2026, 22:20
cmmcnamara
Leakshield Constantly Gets Wet - How to Diagnose
dimanche 1 février 2026, 02:34
Hi, I am trying to diagnose an issue I have been experiencing with my Leakshield.
I have the Leakshield mounted on an Ultitube 200 which I've had for about two years. The Ultitube is mounted on an external MORA which is run by two D5's. This keeps coolant temperatures around 25°C-28°C max depending on what I am running.The system is running clear DP Ultra.
Over the course of the past two years, I've had to replace the membrane a number of times from getting it wet.
The first time I accidentally over filled the reservoir and when the Leakshield would engage, it would suck water high enough into it. Not an issue. Cleaning didn't work but the membrane replacement did. Leakshield worked well for about a month. Eventually I had to do a second replacement. This time it appeared to me that during startup, splashing of the pump through the reservoir base was still getting fluid up onto the Leakshield. I drained more liquid (filled about 45-50%, unsure exactly, Leakshield has never adequately detected the proper level). After this second replacement the unit worked fine for 6-8 months, no issues.
Suddenly, the Leakshield started struggling to pull pressure one day and failed the health test. After I pulled it off and inspected, water was yet again all over the surface as well as the membrane which was surprising. A third replacement fixed it for a time but failed again with the same issue within a month or so. During this month the Leakshield behaved oddly. Struggling to get to pressure, sometimes oscillating and setting off alarms as it did so but once at pressure would be fine. Eventually this happened again, with fluid again on the Leakshield surface and membrane. A fourth replacement did not fix any thing and the unit seemed to never be able to reach pressure again.
I thought it may just be the Leakshield had worn out and maybe had gotten wet too often. Also, since I run two D5's at 50%, the pressure needed to be a bit high (390 mbar) for my system which may have contributed. Not an issue, I just ordered a second Leakshield and left the old in place, disconnected for a few weeks but ran the system normally. When the new Leakshield arrived, I pulled the old one off and saw yet again that the Leakshield surface was wet.
To avoid risking my new Leakshield I just replaced the old Leakshield with the normal reservoir cap. After using the system for a few hours, I can see this surface get wet as well (although the layer is much thinner after just a few hours and not in large droplets).
I am having trouble trying to diagnose what is causing this and do not want to risk damaging the new Leakshield in the same way. At first I was thinking this might be condensation but I can't see how that would happen. My system temperatures are rather low on average. I've fixed any splashing issues with the reservoir fill level. I cannot determine how the top surfaces still continue to get wet. And if this continues this way, I don't see how the new Leakshield won't fail in the same way. Is there something wrong with way I have been operating the Leakshield?
TLDR: Leakshield membrane/inner surface build up liquid/condensate causing the Leakshield to fail or need constant membrane replacements. Has anyone dealt with this before and knows how to fix this before I install a new Leakshield?
Teasuti
mercredi 4 février 2026, 14:36
The root cause is moisture on the membrane. Reservoirs are usually closed environments with liquid in them, so the air in them is going to be humid. It is only natural that at 100% relative humidity condensation may occur on the walls of the tank. It will be dripping on the membrane just the same. It's a natural phenomena, nothing we can do about it. Like when you're at the spa and water is dripping on the windows at the indoor pools. It's inevitable.
I say the membrane is not fit for the purpose and in extension this is a design fault (and I hold my stance on this claim). It can only work whilst it's dry. Once it's saturated, it blocks air passage.
I have the same track record with my Leakshield, with the membrane getting clogged, then the pump activation goes up and start to give off false alarms because of the repeated activation in short bursts.
You can find my posts on this forum about the same reports. I only replaced the membrane once till I figured this is going to be an uphill battle.
I'll be honest with you. I have no solution to it. The support dismissed the case. The forum members' mileage may vary. Some use it without trouble, and then there are those like us with the issues.
I suppose you could air-dry the device for a day every time this happens and make it into a maintenance habit...
Mine had just been demoted to an expensive tank cap... I can't be bothered to open up the case and take off the Leakshield every week.
If you have two Leakshields and are willing to experiment with one of them at the expense of its service life, then you could try using it without the membrane. This should remove any resistance in the air passage, so the pump could build up pressure effectively in the whole loop, instead of just pumping that tiny pocket behind the membrane in short bursts (and wait till the pressure equalises on the two sides of the membrane).
But be warned that the pump won't be sealed against the fluid then, so even if there's no direct contact, the moisture would get in the pump. I haven't a clue how resistant the internals are against moisture, so this could either be a long or a rather short experiment before the device malfunctions. You may also start to lose some fluid over time in the form of evaporation, as the pump would then just extract it without the membrane. Effectively you'd have an open loop this way - still pressurised of course, but with a clear path for evaporation to the open air.
Let us know how you get along, if you do this experiment. :)
Ce message a été modifié 3 fois. Dernière modification effectuée par "Teasuti" (4 février 2026, 14:48)
Gaetan
dimanche 29 mars 2026, 12:11
I'm experiencing the same problem here. I have to remove the LeakShield and carefully dry the membrane with a microfiber cloth about once a week when I use the system in a way that heats up the water.
Someone from Aquacomputer suggested leaving the protective plastic on the membrane and trying it that way.
Another solution I'm considering is reducing the water volume to leave more space along the tank walls for the moisture to spread.
However, it would be better if someone from Aquacomputer could provide a proper solution to this issue.
Regards
