• 30.11.2026, 22:05
commoncred
Aquasuite Feature Request: Fan controller step up/down using %/sec
mercredi 11 février 2026, 16:54
Hello - Please redirect me if this isn't the right place to do this or if this feature exists somehow and I just haven't found it yet.
I am requesting that when using the Curve Controller mode in Aquasuite that there is a feature that allows a maximum step up and step down percentage per second. The idea being that if my CPU suddenly spikes from 30C to 75C that the most the fans will increase is X percent per second until it reaches the desired value. This would prevent a sudden fan speed spike from occurring if the load was simply momentary and would allow for a quieter user experience by allowing the fans to ramp up (or down) a little slower.
Here is an example of what I'm proposing:
[img]https://forum.aquacomputer.de/index.php?page=Attachment&attachmentID=11298&h=49d923804b4c47b9e8f989abb851062d64683343[/img]
commoncred a envoyé l’image suivante :
mercredi 11 février 2026, 18:26
This is easy to solve.
You don't forward the CPU sensor, but rather your own virtual sensor.
In Playground, create a new temperature sensor and set the CPU temperature as the source. Then create a low-pass filter between the source and the output.
commoncred
mercredi 11 février 2026, 19:05
Thank you so much! This was exactly the thing I was looking for.
jeudi 12 février 2026, 05:22
Yes, the aquasuite's virtual sensor is extremely powerful, and allows one to do a lot of things... even things that should not be done.
Ramping the fans up and down with CPU temperature spikes in a water loop is as useful as tits on a bull.
The fans only effect the coolant in the radiator, the coolant in the CPU block during the temp spike is not directly affected by the fans.
Your most useful control source for the fans is the coolant temperature exiting the radiator... that is what the fans impact.
Discussions similaires
