• 22.11.2026, 20:51
Dramion
Ampinel and HWinfo64
mercredi 25 février 2026, 02:24
Hello,
I for some reason cannot add a new comment to the existing ampinel thread. It keeps logging me out and saying I don't have permission. I'm wondering if at some point we'll get the ability to use HWinfo64 to monitor the information. From what I have seen with the other product of this type, HWinfo64 is willing to work with companies.
mercredi 25 février 2026, 09:08
Already integrated and will be rolled out with the next HWiNFO update.
FLiNT
mercredi 25 février 2026, 15:40
[attach]11336[/attach]
Any additional cables other than the internal USB one that comes with the Ampinel needed for it to work?
mercredi 25 février 2026, 16:07
No, the inclued USB cable is enough.
RE: Ampinel and HWinfo64
mercredi 25 février 2026, 22:17
Hello,
I believe this forum software sets a cookie when you log in. If you do not allow cookies, it won't recognize you when it checks.
I have my browser set to allow cookies and delete all cookies when I exit.
Dramion
dimanche 1 mars 2026, 03:23
Amazing!!! Thank you for replying and even showing a screenshot :!:
Zeejay
jeudi 5 mars 2026, 20:09
Got my Ampinel this morning, the HWINFO64 support is working great and it's quite detailed.
Dramion
Ampinel Received and Installed
vendredi 6 mars 2026, 16:15
I wanted to say that I received my Ampinel yesterday only 3 days to Wisconsin for shipping from Germany is crazy via DHL.
The device feels very well built and solid, with no sense of flimsiness. The instructions were clear and easy to follow. I particularly appreciated the notice included at the top of the packaging advising users to ensure the device does not touch the video card, which is a thoughtful safety reminder.
Installing the device required a bit of effort at first, but once the connectors were fully seated and the audible clicks from both power connectors were heard, the fit felt secure and reliable. From what I can tell, the connection is solid.
The instructions also clearly explain how to connect the USB header to the motherboard. The device functioned immediately after installation with HWinfo, without the need to install the custom software, which was a pleasant surprise.
Overall, the installation process was straightforward and the build quality appears excellent.
Guessing the only way to know if there is a firmware update is to check for it using the custom software. I didn't see any specific URLs to check manually for a new update as an example. Just have to run the software monthly or so and check for new Firmware.
Dramion
samedi 7 mars 2026, 05:12
Anyone know of additional details on using the Ampinel? I have it all setup, working great. Questions I have.
  1. After installing the software and running the balance load detector. Do you have to leave the service running and the Aquasuite software? Or, can the service be stopped and the Aquasuite be exited and it still perform the balancing?
  2. How does the Alarm work? Do you need the service and software running for the Alarm to work or if you set it all in the software to how you want, it'll use those settings even without the service running and software?
samedi 7 mars 2026, 10:58
AMPINEL operates autonomously and protects the graphics card even without the use of the aquasuite software or a USB connection. The integrated balancer is activated ex works and an optical and acoustic alarm is triggered in the event of problematic operating conditions. In critical operating conditions, AMPINEL switches off the graphics card.
Some functions cannot be used without the background service. You will not get pop-up messages in Windows, applications with high GPU load cannot be terminated automatically, and it is not possible to shut down Windows. The latter could still be configured via the signal output and the corresponding cable.
Discussions similaires
