• 30.11.2026, 22:15
PaulyPauly1
OCTO - QUADRO Fan setup
samedi 21 mars 2026, 18:25
I currently have an OCTO, Splitty9, 11 fans, D5 pump and a High Flow Next (water temp sensor/air temp sensor). I have setup a Delta T to control the fans and pump. It works great, however, i would really like to see all the individual RPM readings from each fan. I understand adding a QUADRO can do that, while removing the Splitty9 completely from my system.
My question, Instead of having to recreate the fan curve controller that's on my OCTO, can i copy and paste the configuration onto the QUADRO, or is it better to create the fan profile in the playground and link them all that way. If so, how do i do this?
Also, will there be one place i can see all the fans/RPM instead of having to go between the OCTO and Quadro tabs in Aqua suite. Bit of a n00b here, so please go easy :thumbsup:
Thanks in advance.
Jeff3F
RE: OCTO - QUADRO Fan setup
mardi 24 mars 2026, 01:13
Thanks in advance.
Hi there! I'm using a kludge of the (Deutsche) website in German mode with google translating (otherwise only English is in English). If I understand correctly, you're using both an OCTO and a QUADRO to run 11 fans, one pump, and one flow-meter that includes its own coolant sensor (and ambient inside-the-case air sensor??).
I guess this begs the question for more info - why 11 different fans, are they all truly independent fans in your case? For example, my computer has 10 fans, but grouped. Three radiators, each with 3 fans (3 groups), and another standalone fan. So my OCTO is dealing with four fan groups, and also my D5 PWN pump (technically a "fan" for purpose of Aquasuite). Can you please share more about your setup? Thank you! Jeff
Discussions similaires
