• 12.11.2026, 22:14
Timstone
Flow direction
lundi 21 mars 2005, 13:54
Hi again,
Maybe this question sounds a bit stupid, but what is the correct flowdirection?
Pump --> Reservoir --> CPU --> Radiator --> Pump
Men may control the free world, but women control the boobs. Brent in Player vs. Player
cronix
Re: Flow direction
lundi 21 mars 2005, 14:04
the reservoir should be in front of the pump, all other flowdirections are all the same
Timstone
Re: Flow direction
lundi 21 mars 2005, 14:06
So the correct flowdirection should be:
Reservoir --> Pump --> CPU --> Radiator --> Reservoir
JHC
Re: Flow direction
lundi 21 mars 2005, 17:57
Hi Timstone,
yes, it is importent that the reservoir is directly in front of the pump. All the other components could connected between pump and reservoir, so that you could pass them most suiteable.
reservoir -> pump -> all the other -> reservoir
Jens
Timstone
Re: Flow direction
lundi 21 mars 2005, 19:07
Alrighty then! Thanks for the help all!
