• 20.11.2026, 23:45
larsiano
Koolance 1/4"(6mm) Tubing
vendredi 25 mars 2005, 19:57
My question:
Is it posible to fit a Koolance 1/4"(6mm) tube on an Aqua Computer Cuplex Pro P4-478
& The aquagraFX Komplettkühler 6800 Revision 2 ;D
Any advice would help :o ::)
cheers,
back_orifice
Re: Koolance 1/4"(6mm) Tubing
vendredi 25 mars 2005, 19:58
What is this "Koolance"? ???
Timstone
vendredi 25 mars 2005, 20:18
No links to other manufacturers please
Men may control the free world, but women control the boobs. Brent in Player vs. Player
larsiano
vendredi 25 mars 2005, 23:03
Citation de "back_orifice"
It's the case as shown above with build in radiator +dual pump (1000L/h) & reservoir.
All the tubes have the 1/4" size :-/
back_orifice
vendredi 25 mars 2005, 23:22
It is possible to use the Plu'n'Cool Adapters for Radiators und connect the cooler with the radiator by 8/6mm tubes...
Top_Nurse
samedi 26 mars 2005, 00:33
Citation de "larsiano"
Well...not really. The problem is that the pneumatic fittings used by A-C are designed for a specific outside diameter (OD) hose. Their hose is 6mm ID and 8mm OD. The Koolance hose is 6mm ID and 9mm OD. But there is a solution! I believe you can use A-C hose on your Koolance coolers and radiator parts as the Koolance devices use ferrel-less compression fittings that need 6mm ID hose and I don't think the extra 1mm on the OD will affect the nut from going over the tubing.
You can find some similar issues at http://www.hardforum.com/showthread.php?…3&page=29&pp=40 and also at my homepage: http://home.earthlink.net/~topnurse/
Another possible solution is to change over the G 1/8 fittings on your A-C cooler to the one you need. You can see this discussion also at the [H]ardForum link listed above. ;D
Top_Nurse
samedi 26 mars 2005, 18:18
I think you guys need to get out and about more ;) 8)
SNTmods
mardi 29 mars 2005, 18:46
Without messing with the Koolance setup you can just switch out the AC water block supplied fittings for some Koolance compatible barb fittings. I have a bunch of them. :)
-Dan
Was an early adopter of Aqua-Computer watercooling in the U.S.
