• 11.10.2026, 10:16
Mr_modnaR
Another Aquaero plugging in type question!
dimanche 17 avril 2005, 17:28
Hi all, i've been reading thru the aquaero manual, and i can't figure out if you can connect the aquaero to the power button leads of the motherboard along with a physical power button, i.e. in parallel, so that the aquaero can turn the pc off via the power button connection, as well as having that option myself, rather than having it turn it off the other way (via the atx ps_on# wire.). i hope you can understand my babblings well enough to help! cheers
Re: Another Aquaero plugging in type question!
dimanche 17 avril 2005, 17:34
Yes, that is possible:
Mr_modnaR
dimanche 17 avril 2005, 17:39
excellent :D, also, a bit off topic, but connected with this post: can you just connect an led directly to the power and hdd led pins on the motherboard, or do you need a resistor? i'm not sure what voltage these pins put out. ta
dimanche 17 avril 2005, 17:48
Normally you won't need a resistor. If you have a voltmeter you could check the voltage.
Mr_modnaR
dimanche 17 avril 2005, 17:52
Cheers Shoggy! as a reward for your help:
A joke!
Why did the scarecrow win a Nobel prize?
Because he was oustanding in his field!
Mr_modnaR
dimanche 17 avril 2005, 20:26
continuing on from my original question: do you still need the 'aquaero power connect cable' (Art.-Nr.53041) if you connect the aquaero as in shoggy's diagram? (just trying to keep the interior tidy, you see! can't have spaghetti everywhere :'()
