• 22.11.2026, 21:33
Mr_modnaR
Rad mounting problem
lundi 25 avril 2005, 22:19
Hi all,
I want to mount my rads to the case of my pc.
Is it better to mount the fans to the rad and then the fans to the case, so the weight of the rads are held by the fan's shrouding?
Alternatively, is it better to mount the fans and rads at the same time, using longer bolts which go thru the case, fans and then into the rads, so that the weight of the rads is held by the case, to a certain extent?
Also while i'm at it: do the AC rads work as well with the air being sucked thru them as they do with the air being pushed thru them?
Cheers guys :)
Ancalagon
Re: Rad mounting problem
jeudi 28 avril 2005, 01:50
Citation de "Mr_modnaR"
You can do this how ever it works best for you. It doesn't make any difference to the functionallity. Usually this would mean using long bolts because it's easiest this way (there are long bolts included with the radiator bezel that is availible in the shop). However, there are two things you should take care of when using long bolts:
1. Don't fasten the bolts too tight. You can deform the fans shrouding by this which can result in the fan becoming noisy or even blocking the fan.
2. Watch out not to use too long bolts! The threads in the radiator doesn't have an end stop. You can damage the radiator if you use too long bolts.
Generally, the cooling effect should be the same, but usually you'll want the fans to blow the warm air out of the case. So if you don't have a very fancy case design this fact will dictate the direction of the fans: sucking through the radiator and pushing out of the case.
-- Hoban Washburn
Mr_modnaR
jeudi 28 avril 2005, 02:08
so, is it not better to have the cool air entering the case at the front and passing over the radiator there? i thought the cooler the air, the more effect it has on the cpu temps?
i have a Lian Li PC-6085A case, not amazingly good for cooling i know, but i was trying to decide on whether to have two aiplex evo160s at the front which would require some modding ;D
or one at the front in the standard fan holes and one at the back, in which case, i'd have to cut a larger hole at the back, cos there's only one 80mm fan hole. :-/
cheers
Ancalagon
jeudi 28 avril 2005, 13:42
This in fact can be better. You will of course get a lower water temperature this way, but you will also have a higher air temperature inside the case. So everything that's cooled by the water cooling system is cooled better, but everything else is heated up...
-- Hoban Washburn
Mr_modnaR
jeudi 28 avril 2005, 16:42
I see.... so really it would be best to have the rads at the front, but fabricate some ducting to exhaust the hot air straight out of the side. in this case though, i would need to get some cool air in another way to cool the other components that aren't water-cooled, wouldn't i?
