• 22.11.2026, 22:04
Ze@lot
best way to fit aquabay ???
dimanche 24 avril 2005, 22:21
lo peeps,
just wondering if there is a recommend way of fitting
aquastream to aquatube when installing in aquabay.
looks like im gonna need angle connectors to come out
of aquastream. if some1 has some nice piccies can they
post.
thanks.
Ze.
Re: best way to fit aquabay ???
lundi 25 avril 2005, 02:27
Hi and welcome to the forum :)
You will need angle connectors. Some pictures:
Ze@lot
lundi 25 avril 2005, 20:57
cheers Shoggy,
just what i needed, you just saved me a lot of time and
trouble, cause the way i was thinking of installing them
did not allow for the flex made by the aquastream
anti-vibe coupling.
thanks
Ze.
Sib
mardi 26 avril 2005, 00:35
This is how I mounted my AquaBay. If you want to use the AquaJet you will have to use something like the anti-vibration couplings.
Ze@lot
mardi 26 avril 2005, 21:14
cool thanks sib, nice layout
looks like im gonna have to wait a little longer to install it
as im still waiting for replacement parts that was missing
from my order from leftclicks. hopefully it will come soon.
thanks
Ze.
Top_Nurse
mardi 26 avril 2005, 23:16
Nice Pic! And excellent work...I'm doing mine in a similar way. I will post pics later this weekend.
enriqueeeee
mercredi 27 avril 2005, 00:07
isnt te metal pipe touching your pump and thus is the the ruber thingys are a bit useless and the pump gives vibrations to the reservoir ?
it does look nice though :)
Sib
mercredi 27 avril 2005, 01:51
The fitting coming out of the AquaTube/AquaJet is not hitting the pump. The is why you need the anti-vibration couplings.
I was getting a rattle off the 90 degree elbow I have. It would rest on the bottom bar of the AquaBay, I just had to add some tape to dampen it and now it is almos silent.
shonuff
dimanche 1 mai 2005, 04:25
Sib, nice job Bro. I bought a Aquajet and I am not using it. Well I wasn't using it until now. ;D
Using the Aquastream do you still get a "nice" effect from the water splashing off of the front?
Here is my current set up.
