• 13.11.2026, 17:00
Mr_modnaR
Re: Silver water blocks?
mercredi 27 avril 2005, 16:55
the aquagraFX for 6600 pci express looks like:
http://www.aquacomputer.de/cgi-bin/shop5…0-PCE-2-500.jpg
the mounting holes on it look like the twinplex 6800 mounting holes to me:
http://www.aquacomputer.de/cgi-bin/shop5…ex_6800_500.jpg
as for the NB cooler, you say a capacitor is in the way, is this on the mobo itself? cos i looked at a picture of your mobo, and it looked like there was lots of room round the NB  :-/
Top_Nurse
lundi 2 mai 2005, 03:13
Citation de "Mr_modnaR"
...as for the NB cooler, you say a capacitor is in the way, is this on the mobo itself? cos i looked at a picture of your mobo, and it looked like there was lots of room round the NB
Actually there is a capacitor there that if you don't use a modified ATi screen and/or twist the block it will possibly short out the MB. This has already happened to several people here in the USA :'( and I don't wish to have the same problem. I'm currently using a Koolance GPU-180-V06 cooler as it is the smallest one made that I know about and fits the push-fit (P&C) tubing that A-C uses in their loops.
