• 09.10.2026, 00:45
Mr_modnaR
Aquabay CF pics?
dimanche 8 mai 2005, 15:22
Hi all...
does anybody have any pics of the rear of an aquabay cf? in particular the mountings for the screen?
cheers muchly!
Top_Nurse
Re: Aquabay CF pics?
lundi 9 mai 2005, 13:57
http://www.aqua-computer.de/prodimg/nd_p…f_seite_200.jpg
I think the only difference is that the front panel has a bigger hole. Otherwise I believe it is the same.
Mr_modnaR
lundi 9 mai 2005, 16:42
what i meant was: how does the lcd screen attach to the aquabay? is it to the side mounts? or is it to the front panel?
(that's why i needed a pic of the back :D)
cheers anyway top nurse!
Top_Nurse
lundi 9 mai 2005, 22:19
I don't think it attaches to the front plate.
Mr_modnaR
lundi 9 mai 2005, 22:41
Thank you! i found this pic, and it looks like you're right:
http://www.aqua-computer.de/cgi-bin/shop…abay_15_500.jpg
looks like it's the same aquabay for the aquatube and the lcd screen, they just use a different front plate. the screen appears to be attached to the mounts that are set back from the front.
