• 26.11.2026, 03:30
Xarig
Aquero Problem + Cuplex Evo fitting question
mercredi 11 mai 2005, 02:16
Hi folks, this is my first post :)
Unfortunately it's to get some advice about my very tempramental Aquero. I have just installed it in my brand new system - I'll post some pictures in time.
The AqueroUSB software sometimes detects the Aquero and sometimes doesn't. Is this a known issue with and Asus A8N mother board.
I might try upgrading the firmware - has anybody done this yet? It look like a complicated process for me. Unplugging the sensors etc. means dismatling half the front of my PC :P
ANy help would be greatly appreciated. I could also do with a manual of some sort for JALCD - I have a VFD Aquero, does JALCD work with that? If it does how do you use it, I have been singularly unsuccessful so far :'(
Re: Aquero Problem
mercredi 11 mai 2005, 02:41
Hi and welcome to the forum :)
There have been several problems with Asus boards...
I highly recommend to flash the new OS and firmware. Then you can use the brandnew Aquasuite and believe me when I say it's awesome 8) It should also fix the problem with your mainboard.
Here you will find a (unofficial) translation for the updating procedure.
A lot of people have done it :)
jalcds also works with the vfd version. You have to start the programm via the start-menu or via a shortcut that contains a parameter: "D:\Programme\jalcds\jaLCDs.exe output=aquaeroLCD.jaLCD"
You should check if the file aquaeroLCD.dll exists within your windows\system32 folder.
Did you try to load the example.cfg? That config should work.
Xarig
Re: Aquero Problem
mercredi 11 mai 2005, 05:34
Thanks for the advice, it's getting really late now so I'll leave it until tomorrow.
Btw, when the CUplex Evo is fitted with the 939 'clip' fittings, should the bolt that squeezes the springs be completely unscrewed? I don't think mine is and it may explain the terrible temperatures I'm getting.
Thanks for the help.
Xarig
Re: Aquero Problem + Cuplex Evo fitting question
samedi 14 mai 2005, 03:47
Flashed the Aquaero and installed Aquasuite - very nice ;D
I was wanting to ask - what kind of flow rate should my flowsensor be getting from an Aquastream pump? It's currently showing 35L/H seem low to me - should I be worried. ???
Thanks for the help
Xarig
Re: Aquero Problem + Aquastream Quaestion
Oops didn't mean to post again - was trying to change the main title. New I should have tried harder in those German lessons :-[
