• 20.11.2026, 07:22
Top_Nurse
Adpater fittings for Aquastream
mardi 10 mai 2005, 02:54
Does anyone know if the adapter fittings for the Aquastream pump is available without the Plug & Cool fittings?
IT-TRADE.NET
Re: Adpater fittings for Aquastream
mardi 10 mai 2005, 13:14
Yes, you can also have them with e.g. Pneumatic fittings ;)
x-stars
mardi 10 mai 2005, 13:50
Maybe it's easier for you to get the fitting from an Eheim 1046 - they are available in lots of shops and the "Gewinde" are the same ;)
Top_Nurse
mardi 10 mai 2005, 22:53
Citation de "IT-TRADE.NET"
Uh..no, what I meant are they available in bulk without any fittings? Just the adapter set :)
Top_Nurse
mardi 10 mai 2005, 23:03
Citation de "x-stars"
Well unfortunately, the one I currently have is made by Innovatek and it is about 6mm too long. I'm going to just turn the one down I have for a temporary solution, but wanted to get a better solution from Aqua Computer. ;D
Another possibility is to get a 90* (bent) elbow with G 3/8 threads on one end and a 8mm Plug & Cool on the other and completely eliminate the adapter fitting. I think I would have to add an o-ring to the thread relief for sealing purposes, but it might work better. Anyone ever done this before? 8)
IT-TRADE.NET
samedi 14 mai 2005, 21:30
As you can dismount the fittings from the adapters it's just that you have to pay for the fittings.
Take your AC multitool ;) do a little screwing and then use whatever fittings you want. Only take care that the new fittings are G1/8.
