• 22.11.2026, 22:30
Top_Nurse
Cool Current 450
lundi 16 mai 2005, 00:07
Greetings...
What is the Cool Current 450 rated at temp wise? Can it pump a solid 450 watts continuous at say 45-50 degrees Celcius?
Also is it a H20 retro-fit of an existing standard PSU or was it designed from the ground up as a H20 cooled PSU?
Does it have SLI outputs for two video cards?
Mr_modnaR
Re: Cool Current 450
lundi 16 mai 2005, 00:47
it depends how much heat your system can dissipate.
providing it can dissipate enough, you should have no problems. ;D
Mr_modnaR
lundi 16 mai 2005, 01:39
i heard somewhere it was a water-cooled version of a passive psu.
apparently the only problem with the passive one was that it wasn't that effective at expelling the heat, but there waas no problems with the water-cooled one
