• 22.11.2026, 21:25
Top_Nurse
Bulkhead fitting info needed
mercredi 25 mai 2005, 01:25
Greetings most exalted ones...
I need to know who the manufacturer is of the bulkhead fittings I just got from Sharka here in the states. They are the standard ones A-C sells and they have blue color releases on them. It says on the fitting "CDC" which I assume is the initials of the manufacturer. I found a website called CDC Pneumatics in Korea that appears to be where these were manufactured. Is this the correct company? I need to contact whoever made these so I get the black color plastic release buttons as blue sticks out like a sore thumb in my case :-/
Mr_modnaR
Re: Bulkhead fitting info needed
mercredi 25 mai 2005, 01:42
FYI: RS do all black bulkhead fittings! ;D
Stefan_K.
mercredi 25 mai 2005, 02:06
you can buy them at aqua computer and no it´s no Korean manufacturer and no we won´t tell you who it is.
Topic Closed
Stefan
